Gibbs Measures on Attractors in Biological Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
We consider a class of nonreversible processes with a local interaction as a model of biological neural networks. We study the structure of equilibrium measures on attractors. There exist first and second order phase transitions with respect to the grey level parameter.
Autre [cs.OH]
RR-3189.pdf (296.76 Ko) Télécharger le fichier
inria-00073500 , version 1 (24-05-2006)
  • HAL Id : inria-00073500 , version 1
Vadim A. A. Malyshev, T.S Turova. Gibbs Measures on Attractors in Biological Neural Networks. [Research Report] RR-3189, INRIA. 1997. ⟨inria-00073500⟩
25 Consultations
74 Téléchargements
