Tiling with Limited Resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
In the framework of perfect loop nests with uniform dependences, tiling has been extensively studied as a source-to-source program transformati- on. Little work has been devoted to the mapping and scheduling of the tiles on to physical processors. We present several new results in the context of limited computational resources, and assuming communication-computation overlap. In particular, under some reasonable assumptions, we derive the optimal mapping and scheduling of tiles to physical processors.
Autre [cs.OH]
RR-3183.pdf (304.62 Ko) Télécharger le fichier
inria-00073506 , version 1 (24-05-2006)
  • HAL Id : inria-00073506 , version 1
Pierre-Yves Calland, Jack Dongarra, Yves Robert. Tiling with Limited Resources. [Research Report] RR-3183, INRIA. 1997. ⟨inria-00073506⟩
144 Consultations
185 Téléchargements
