Admission Control in Stochastic Event Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
In this paper, we show that the expected workload and the expected waiting time in (max,+) linear system under a single input sequence is multimodular. We use this result to construct the optimal deterministic admission control in the (max,+) system under rate constraints.
Autre [cs.OH]
RR-3179.pdf (422.58 Ko) Télécharger le fichier
inria-00073510 , version 1 (24-05-2006)
  • HAL Id : inria-00073510 , version 1
Eitan Altman, Bruno Gaujal, Arie Hordijk. Admission Control in Stochastic Event Graphs. RR-3179, INRIA. 1997. ⟨inria-00073510⟩
206 Consultations
196 Téléchargements
