Memory Management Schemes for Radiosity Computation in Complex Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Hierarchical radiosity is a very demanding process in terms of computation time and memory ressources even for scenes of moderate complexity. To handle complex environments, not fitting in memory, new solutions have to be devised. One solution is to partition the scene into subsets of polygons 3D cells or clusters and to maintain in memory only some of them. The radiosity computation is performed only for this resident subset which changes during the resolution process. This change entails many read and write operations from or onto the disk. These disk transfers must be ordered to make the radiosity algorithms tractable. We propose in this paper different ordering strategies which can be seen as complementary to those devised by Teller.
Autre [cs.OH]
RR-3149.pdf (342.64 Ko) Télécharger le fichier
inria-00073540 , version 1 (24-05-2006)
  • HAL Id : inria-00073540 , version 1
Daniel Meneveaux, Kadi Bouatouch, Eric Maisel. Memory Management Schemes for Radiosity Computation in Complex Environments. [Research Report] RR-3149, INRIA. 1997. ⟨inria-00073540⟩
69 Consultations
140 Téléchargements
