Non Overlapping Domain Decomposition for Singularly Perturbed Elliptic Boundary Value Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Marc Garbey
  • Fonction : Auteur
Laurence Viry
  • Fonction : Auteur
  • PersonId : 756531
  • IdRef : 081187793
We analyze the Funaro-Quarteroni alternative procedure for the solution of singular perturbation problems. We show that for an appropriate choice of the domain decomposition, one obtains a fast convergent iterative scheme with {\it no relaxation} that resolves the boundary layers. The convergence is superlinear with respect to the singular perturbation parameter $\epsilon$ in the following sense: the amplification factor is $o(\epsilon)$. We give sharp estimates of the interface position and convergent rates for an homogeneous domain decomposition in one dimensional space as well as in two dimensional space problems on a disk. We extend our results to heterogeneous domain decomposition arising in a simplified model of an electromagnetic problem. We report on implementation results with finite difference approximations and finite element codes ({\it Modulef})
RR-3137.pdf (463.91 Ko) Télécharger le fichier
inria-00073552 , version 1 (24-05-2006)
  • HAL Id : inria-00073552 , version 1
Marc Garbey, Laurence Viry, Olivier Coulaud. Non Overlapping Domain Decomposition for Singularly Perturbed Elliptic Boundary Value Problems. [Research Report] RR-3137, INRIA. 1997, pp.45. ⟨inria-00073552⟩
96 Consultations
75 Téléchargements
