Fault Detection and Isolation in Nonlinear Dynamic Systems: A Combined Input-Output and Local Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Qinghua Zhang
  • Fonction : Auteur
  • PersonId : 830741
Michèle Basseville
Albert Benveniste
The problem of fault detection and isolation (FDI) is addressed for nonlinear dynamic systems modeled by polynomial differential-algebraic equations. Ritt's algorithm is used to obtain an input-output representation of the monitored system by eliminating unknown variables. A local approach to change detection is then applied to the input-output representation for FDI residual generation and evaluation. Simulation results on a microbial growth process are provided, which illustrat- e the relevance of the proposed FDI method.
RR-3120.pdf (378.12 Ko) Télécharger le fichier
inria-00073570 , version 1 (24-05-2006)
  • HAL Id : inria-00073570 , version 1
Qinghua Zhang, Michèle Basseville, Albert Benveniste. Fault Detection and Isolation in Nonlinear Dynamic Systems: A Combined Input-Output and Local Approach. [Research Report] RR-3120, INRIA. 1997. ⟨inria-00073570⟩
230 Consultations
666 Téléchargements
