Declarative Specialization of Object-Oriented Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Designing and implementing generic software components is encouraged by languages such as object-oriented ones and commonly advocated in most application areas. Generic software components have many advantages among which the most important is reusability. However, it comes at a price: genericity often incurs a loss of efficiency. This paper presents an approach aimed at reconciling genericity and efficiency. To do so, we introduce declarations to the Java language to enable a programmer to specify how generic programs should be specialized for a particular usage pattern. Our approach has been implemented as a compiler from our extended language into standard Java.
RR-3118.pdf (333.52 Ko) Télécharger le fichier
inria-00073572 , version 1 (24-05-2006)
  • HAL Id : inria-00073572 , version 1
Eugen-Nicolae Volanschi, Charles Consel, Gilles Muller, Crispin Cowan. Declarative Specialization of Object-Oriented Programs. [Research Report] RR-3118, INRIA. 1997. ⟨inria-00073572⟩
166 Consultations
417 Téléchargements
