How to Select Optimal Portfolio in Alpha-Stable Markets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
This paper generalizes the traditional Mean-Variance method in portfolio analysis when asset returns are assumed to be jointly stable. An $\alpha$-stable efficient frontier is computed and compared to the classical Gaussian one. The efficient frontier computed from this analysis model dominates the one defined in terms of the Markowitz portfolio selection model criterion.
Autre [cs.OH]
RR-3100.pdf (373.14 Ko) Télécharger le fichier
inria-00073591 , version 1 (24-05-2006)
  • HAL Id : inria-00073591 , version 1
Lotfi Belkacem. How to Select Optimal Portfolio in Alpha-Stable Markets. [Research Report] RR-3100, INRIA. 1997. ⟨inria-00073591⟩
115 Consultations
196 Téléchargements
