s'authentifier
version française rss feed
inria-00073746, version 1
Second Order Necessary and Sufficient Optimality Conditions under Abstract Constraints
J. Frederic Bonnans () 1, Roberto Cominetti, Alexander Shapiro
N° RR-2952 (1996)
Résumé : In this paper we discuss second order optimality conditions in optimization problems subject to abstract constraints. Our analysis is based on various concepts of second order tangent sets and parametric duality. We introduce a condition, called second order regularity, under which there is no gap between the corresponding second order necessary and second order sufficient conditions. We show that the second order regularity always holds in the case of semi-definite programming.
  • Domaine : Informatique/Autre
    Mathématiques/Optimisation et contrôle
  • Mots-clés : SECOND ORDER OPTIMALITY CONDITIONS / SEMI-DEFINITE PROGRAMMING / SEMI-INFINITE PROGRAMMING / TANGENT SETS / LAGRANGE MULTIPLIERS / CONE CONSTRAINTS / DUALITY
  • Référence interne : RR-2952
  • Commentaire : Projet PROMATH
  • inria-00073746, version 1
  • oai:hal.inria.fr:inria-00073746
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 13:40:10
  • Dernière modification le : Mercredi 18 Juillet 2007, 11:58:30
tous les articles de la base du CCSd...
