inria-00074058, version 1
Voronoi Diagrams in Higher Dimensions under Certain Polyhedral Distance Functions
Jean-Daniel Boissonnat
1Micha SharirBoaz TaganskyMariette Yvinec
N° RR-2629 (1995)
Résumé : The paper bounds the combinatorial complexity of the Voronoi diagram of a set of points under certain polyhedral distance functions. Specifically, if $ß$ is a set of $n$ points in general position in $\Ee maximum complexity of its Voronoi diagram under the $\Linf$ metric, and also under a simplicial distance function, are both shown to be $\Theta(n^{\lceil d/2 \rceil})$. The upper bound for the case of the $\Linf$ metric follows from a new upper bound, also proved in this paper, on the maximum complexity of the union of $n$ axis-parallel hypercubes in $\E complexity isof $\Theta(n^{\ceil{d/2}})$, for $d \ge 1$, and it improves to $\Theta(n^{\floor{d/2}})$, for $d \ge 2$, if all the hypercubes have the same size. Under the $L_1$ metric, the maximum complexity of the Voronoi diagram of a set of $n$ points in general position in $\Eown to be d $\Theta(n^2)$. We also show that the general position assumption is essential, and give examples where the complexity of the diagram increases significantly when the points are in degenerate configurations. Finally, on-line algorithms are proposed for computing the Voronoi diagram of $n$ points in $\E under a simplicial or $\Linf$ distance function. Their randomized complexities are $O(n \log n + n ^{\ceil{d/2}})$ for simplicial diagrams and $O(n ^{\ceil{d/2}} \log ^{d-1} n)$ for $\Linf$-diagrams.
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Mots-clés : COMPUTATIONAL GEOMETRY / VORONOI DIAGRAM / POLYHEDRAL DISTANCE FUNCTION
- Référence interne : RR-2629
- inria-00074058, version 1
- http://hal.inria.fr/inria-00074058
- oai:hal.inria.fr:inria-00074058
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Mai 2006, 14:24:18
- Dernière modification le : Mercredi 31 Mai 2006, 14:24:28
Documents associés
Exporter
