s'authentifier
version française rss feed
inria-00074107, version 1
An Output-Sensitive Convex Hull Algorithm for Planar Objects
Franck Nielsen 1, Mariette Yvinec ()
N° RR-2575 (1995)
Résumé : A set of planar objects is said to be of type $m$ if the convex hull of any two objects has its size bounded by $2m$. In this paper, we present an algorithm based on the marriage-before-conquest paradigm to compute the convex hull of a set of $n$ planar convex objects of fixed type $m$. The algorithm is \mbox{output-sensitive}, i.e. its time complexity depends on the size $h$ of the computed convex hull. The main ingredient of this algorithm is a linear method to find a {\em bridge}, i.e. a facet of the convex hull intersected by a given line. We obtain an $O(n\beta (h,m)\log h)$-time convex hull algorithm for planar objects. Here $\beta (h,2)=O(1)$ and $\beta (h,m)$ is an extremely slowly growing function. As a direct consequence, we can compute in optimal $\Theta (n\log h)$ time the convex hull of disks, convex homothets, non-overlapping objects. The method described in this paper also applies to compute lower envelopes of functions. In particular, we obtain an optimal $\Theta (n\log h)$-time algorithm to compute the upper envelope of line segments.
  • Domaine : Informatique/Autre
  • Mots-clés : COMPUTATIONAL GEOMETRY / CONVEX HULL / UPPER ENVELOPE / OUTPUT-SENSITIVE ALGORITHMS
  • Référence interne : RR-2575
  • inria-00074107, version 1
  • oai:hal.inria.fr:inria-00074107
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 14:32:18
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:28
tous les articles de la base du CCSd...
