s'authentifier
version française rss feed
inria-00074113, version 1
Minimal Representation of Uniform Recurrence Equations
Bruno Gaujal () 1, Alain Jean-Marie (), Jean Mairesse ()
SIAM Journal on Computing 30, 5 (2000) 1701-1738
Résumé : We consider a system of uniform recurrence equations of dimension one. We show how the computation can be carried using minimal memory size with several synchronous processors. This result has applications in register minimization for digital circuitry and parallel simulation of timed marked graphs.
  • Domaine : Informatique/Autre
  • Mots-clés : UNIFORM RECURRENCE EQUATIONS / REGISTER MINIMIZATION / STRAHLER'S NUMBER / CIRCUIT DESIGN / (MAX / +) LINEAR SYSTEMS
  • Référence interne : RR-2568
  • Versions disponibles :  v1 (31-05-2006) v2 (27-07-2007)
  • inria-00074113, version 1
  • oai:hal.inria.fr:inria-00074113
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 14:33:04
  • Dernière modification le : Vendredi 27 Juillet 2007, 10:41:01
tous les articles de la base du CCSd...
