Densities of idempotent measures and large deviations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Considering measure theory in which the semifield of positive real numbers is replaced by an idempotent semiring leads to the notion of idempotent measure introduced by Maslov. Then, idempotent measures or integrals with density correspond to supremums of functions for the partial order relation induced by the idempotent structure. In this paper, we give conditions under which an idempotent measure has a density and show by many examples that they are often satisfied. These conditions depend on the lattice structure of the semiring and on the Boolean algebra in which the measure is defined. As an application, we obtain a necessary and sufficient condition for a family of probabilities to satisfy the large deviation principle as defined by Varadhan.
RR-2534.pdf (258.76 Ko) Télécharger le fichier
inria-00074144 , version 1 (24-05-2006)
  • HAL Id : inria-00074144 , version 1
Marianne Akian. Densities of idempotent measures and large deviations. [Research Report] RR-2534, INRIA. 1995. ⟨inria-00074144⟩
114 Consultations
226 Téléchargements
