inria-00074269, version 1
Circular Separability of Polygons
Jean-Daniel Boissonnat
1Jurek CzyzowiczOlivier Devillers
Mariette Yvinec
N° RR-2406 (1994)
Résumé : Two planar sets are circularly separable if there exists a circle enclosing one of the set and whose open interior disk does not intersect the other set. This paper studies two problems related to circular separability. A linear-time algorithm is proposed to decide if two polygons are circularly separable. The algorithm outputs the smallest separating circle. The second problem asks for the largest circle included in a preprocessed, convex polygon, under some point and/or line constraints. The resulting circle must contain the query points and it must lie in the halfplanes delimited by the query lines.
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Mots-clés : COMPUTATIONAL GEOMETRY / PARALLEL ROBOTS
- Référence interne : RR-2406
- inria-00074269, version 1
- http://hal.inria.fr/inria-00074269
- oai:hal.inria.fr:inria-00074269
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Mai 2006, 14:54:18
- Dernière modification le : Mercredi 31 Mai 2006, 14:24:32
Documents associés
Exporter
