s'authentifier
version française rss feed
inria-00074273, version 1
Large scale direct optimal control applied to the re-entry problem
J. Frederic Bonnans () 1, Geneviève Launay 1
N° RR-2402 (1994)
Résumé : We present the numerical solution of an atmospheric reentry problem for a space shuttle. We discretize the control and state with the same grid, and use a large-scale successive quadratic programming technique. With the help of sliding horizon and successive refinement of the discretization, we can solve on a workstation a problem with 1600 time step, an unusually large figure for this kind of real world optimal control problem.
  • Domaine : Informatique/Autre
    Mathématiques/Optimisation et contrôle
  • Mots-clés : OPTIMAL CONTROL / DISCRETIZATION / PATH FOLLOWING / DIFFERENTIAL EQUATIONS / NEWTON'S METHOD / SUCCESSIVE QUADRATIC PROGRAMMING
  • Référence interne : RR-2402
  • Commentaire : Projet PROMATH
  • inria-00074273, version 1
  • oai:hal.inria.fr:inria-00074273
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 14:54:36
  • Dernière modification le : Lundi 14 Mai 2007, 12:21:13
tous les articles de la base du CCSd...
