s'authentifier
version française rss feed
inria-00074301, version 1
Convex Tours of Bounded Curvature
Jean-Daniel Boissonnat () 1, Jurek Czyzowicz a2, Olivier Devillers () 1, Jean-Marc Robert b3, Mariette Yvinec () 1
N° RR-2375 (1994)
Résumé : We consider the motion planning problem for a point constrained to move along a smooth closed convex path of bounded curvature. The workspace of the moving point is bounded by a convex polygon with $m$ vertices, containing an obstacle in a form of a simple polygon with $n$ vertices. We present an $O(m+n)$ time algorithm finding the path, going around the obstacle, whose curvature is the smallest possible.
  • Domaine : Informatique/Autre
  • Mots-clés : COMPUTATIONAL GEOMETRY – MOTION PLANNING – NON HOLONOMY
  • Référence interne : RR-2375
  • inria-00074301, version 1
  • oai:hal.inria.fr:inria-00074301
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 15:00:52
  • Dernière modification le : Mercredi 21 Mars 2007, 11:59:31
tous les articles de la base du CCSd...
