inria-00074546, version 2
Time-varying exponential stabilization of nonholonomic systems in power form
Jean-Baptiste Pomet
1Claude Samson
2
N° RR-2126 (1993)
Résumé : Systems in canonical power form have recently been used to model the kinematic equations of nonholonomic mechanical systems. McCloskey and Murray have had the idea of using the properties of homogeneous systems to derive exponentially stabilizing continuous time-periodic feedbacks for this class of systems. Motivated by this work, the present study extends a control design method previously proposed by Samson to the design of such homogeneous feedbacks. The approach here followed has the advantage of yielding simple and direct stability proofs. Homogeneity-related results needed for time-varying exponential stabilization are also provided.
- 1 : MIAOU (INRIA Sophia Antipolis)
- INRIA
- 2 : ICARE (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Référence interne : RR-2126
- Versions disponibles : v1 (31-05-2006) v2 (07-08-2006)
- inria-00074546, version 2
- http://hal.inria.fr/inria-00074546
- oai:hal.inria.fr:inria-00074546
- Contributeur : Rapport De Recherche Inria
- Soumis le : Lundi 7 Août 2006, 15:04:14
- Dernière modification le : Vendredi 2 Mars 2007, 08:57:54
Documents associés
Exporter
