Using pseudo Kalman-filters in the presence of constraints application to sensing behaviors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
A new generalization of the linear Kalman-filter to non-linear equations is introduced. The deterministic interpretation of this mechanism is discussed. The proposed algorithm is an alternative to the well known extended Kalman filer. A small experimental illustration is given. An application to sensory-motor behaviors is proposed.
Autre [cs.OH]
RR-1669.pdf (818.73 Ko) Télécharger le fichier
inria-00074888 , version 1 (24-05-2006)
  • HAL Id : inria-00074888 , version 1
Thierry Viéville, Peter Sander. Using pseudo Kalman-filters in the presence of constraints application to sensing behaviors. [Research Report] RR-1669, INRIA. 1992. ⟨inria-00074888⟩
56 Consultations
495 Téléchargements
