The space of spheres, a geometric tool to unify duality results on Voronoi diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
We present a framework that allows to easily derive transformations for various kinds of Voronoi and Power diagrams including k-th order and weighted versions. All proofs are essentially geometric and require no analytic calculations. Some new algorithms can be presented in special cases.
Autre [cs.OH]
RR-1620.pdf (386.75 Ko) Télécharger le fichier
inria-00074941 , version 1 (24-05-2006)
  • HAL Id : inria-00074941 , version 1
Olivier Devillers, Stefan Meiser, Monique Teillaud. The space of spheres, a geometric tool to unify duality results on Voronoi diagrams. [Research Report] RR-1620, INRIA. 1992. ⟨inria-00074941⟩
347 Consultations
257 Téléchargements
