s'authentifier
version française rss feed
inria-00075286, version 1
On relationship between term rewriting systems and regular tree languages
Grégory Kucherov 1
N° RR-1273 (1990)
Résumé : If P is a set of open terms, Red(P) is the set of terms that contain at least a subterm which is an instance of a term in P. The main theorem of this paper says that if L is a regular language of ground terms and P is a finite set of open terms such that L \subseteq Red(P), then there exists a finite set P* such that all the terms of P* are linear instances of terms in P and L \subseteq Red(P*). Applications of this result to ground reducibility of term rewrite systems are also discussed. This work was done while the author was visiting INRIA-Lorraine.
  • Domaine : Informatique/Autre
  • Référence interne : RR-1273
  • Commentaire : Projet EURECA
  • inria-00075286, version 1
  • oai:hal.inria.fr:inria-00075286
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 17:52:46
  • Dernière modification le : Jeudi 25 Janvier 2007, 17:13:31
tous les articles de la base du CCSd...
