On the randomized construction of the Delaunay tree - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1989
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Monique Teillaud
The Delaunay is a hierarchical data structure that has been introduced. The Delaunay tree is defined from the Delaunay triangulation and, roughly speaking, represents a triangulation as a hierarchy of balls. It allows us to incrementally construct the Delaunay triangulation of a finite set of n points in any dimension. In this paper, we prove that a randomized construction of the Delaunay tree (and thus, of the Delaunay triangulation) ca be done in 0(n log n) expected time in the plane and in [??] expected time in d-dimensional space. These results are optimal for fixed d. The algorithm is extremely simple and experimental results are given.
Autre [cs.OH]
RR-1140.pdf (435.01 Ko) Télécharger le fichier
inria-00075419 , version 1 (24-05-2006)
  • HAL Id : inria-00075419 , version 1
Jean-Daniel Boissonnat, Monique Teillaud. On the randomized construction of the Delaunay tree. [Research Report] RR-1140, INRIA. 1989. ⟨inria-00075419⟩
149 Consultations
343 Téléchargements
