Lambda-Upsilon-Omega the 1989 cookbook - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1989
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Paul Zimmermann
Lambda--Upsilon--Omega ( \Upsilon\Omega ) is a research tool designed to assist the average case analysis of some well defined classes of algorithms and data structures. This cookbook consists of an informal introduction to the system together with eighteen examples of programmes that are automatically analyzed. Amongst the applications treated here, we find: addition chains, quantitative concurrency analysis of simple systems, symbolic manipulation algorithms such as formal differentiation, simplification and rewriting systems, as well as combinatorial models including various tree and permutation statistics and functional graphs with applications to integer factorisation.
Autre [cs.OH]
RR-1073.pdf (576.09 Ko) Télécharger le fichier
inria-00075486 , version 1 (19-04-2012)
  • HAL Id : inria-00075486 , version 1
Philippe Flajolet, Paul Zimmermann, Bruno Salvy. Lambda-Upsilon-Omega the 1989 cookbook. [Research Report] RR-1073, INRIA. 1989. ⟨inria-00075486⟩
295 Consultations
413 Téléchargements
