s'authentifier
version française rss feed
inria-00077202, version 1
Holls: an Intentional First-Order Expression of Higher-Order Logic
Gilles Dowek 1, Thérèse Hardin, Claude Kirchner 2
N° RR-3556 (1998)
Résumé : We give a first-order presentation of higher-order logic based on explicit substitutions. This presentation is intentionally equivalent to the usual presentation of higher-order logic based on $\lambda$-calculus, i.e. a proposition can be proved without the extensionality axioms in one theory if and only if it can in the other. We show that we can apply the \em Extended Narrowing and Resolution first-order proof-search method to this theory. We get this way a step by step simulation of higher-order resolution. Hence expressing higher-order logic as a first-order theory and applying a first-order proof search method is at least as efficient as a direct implementation. Furthermore, the well studied improvements of proof search for first-order logic could be reused at no cost for higher-order automated deduction. Moreover as we stay in a first-order setting, extensions, such as equational higher-order resolution, are easier to handle.
  • Domaine : Informatique/Autre
  • Mots-clés : higher-order logic – automated theorem proving – deduction modulo – rewriting – skolemization
  • Référence interne : RR-3556
  • Commentaire : Projet COQ – Projet PARA – PROTHEO
  • inria-00077202, version 1
  • oai:hal.inria.fr:inria-00077202
  • Contributeur :
  • Soumis le : Lundi 29 Mai 2006, 17:19:26
  • Dernière modification le : Mardi 20 Juin 2006, 15:57:06
tous les articles de la base du CCSd...
