Using Isolation Spheres for Cooperative Processes Correctness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Adnene Guabtni
  • Fonction : Auteur
  • PersonId : 830150
François Charoy
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Managing cooperation in Business Processes still represents a challenge because of several problems. Concurrent access to common data, coherence of the results, organisation and cooperation correctness are some of them. Looking at isolation problems in the database world and at their solutions using SQL isolation levels, we try to adapt them to the cooperative dimension of processes. In this paper, we identify the phenomena that happen during cooperation in business processes. Then we propose a solution based on isolation spheres to ensure correctness of cooperative processes and customise the exclusion control of the different cooperation phenomena.
cscwd.pdf (255.47 Ko) Télécharger le fichier
inria-00077250 , version 1 (30-05-2006)
  • HAL Id : inria-00077250 , version 1
Adnene Guabtni, François Charoy, Claude Godart. Using Isolation Spheres for Cooperative Processes Correctness. The 10th International Conference on CSCW in Design (CSCWD 2006), Southeast University, May 2006, Nanjing, China. ⟨inria-00077250⟩
54 Consultations
241 Téléchargements
