s'authentifier
version française rss feed
inria-00083370, version 1
Some theoretical aspects of watermarking detection
Teddy Furon a1, Julie Josse 1, Sandrine Le Squin 1
Security, Steganography, and Watermarking of Multimedia Contents VIII 6072 (2006)
Résumé : This paper considers watermarking detection, also known as zero-bit watermarking. A watermark, carrying no hidden message, is inserted in content. The watermark detector checks for the presence of this particular weak signal in content. The paper aims at looking to this problem from a classical detection theory point of view, but with side information enabled at the embedding side. This means that the watermarking signal is a function of the host content. Our study is twofold. The first issue is to design the best embedding function for a given detection function (a Neyman-Pearson detector structure is assumed). The second issue is to find the best detection function for a given embedding function. This yields two conditions, which are mixed into one ‘fundamental' differential equation. Solutions to this equation are optimal in these two senses. Interestingly, there are other solutions than the regular quantization index modulation scheme. The JANIS scheme, for instance, invented in a heuristic manner several years ago, is justified as it is one of these solutions.
  • Domaine : Informatique/Multimédia
  • inria-00083370, version 1
  • oai:hal.inria.fr:inria-00083370
  • Contributeur :
  • Soumis le : Vendredi 30 Juin 2006, 11:16:27
  • Dernière modification le : Jeudi 13 Septembre 2007, 15:32:29
tous les articles de la base du CCSd...
