Dynamic Packet Aggregation to Solve Performance Anomaly in 802.11 Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Tahiry Razafindralambo
Luigi Iannone
Serge Fdida
In the widely used 802.11 standard, the so called performance anomaly is a well known issue. Several works have tried to solve this problem by introducing mechanisms such as packet fragmentation, backoff adaptation, or packet aggregation during a fixed time interval. In this paper, we propose a novel approach solving the performance anomaly problem by packet aggregation using a dynamic time interval, which depends on the busy time of the wireless medium. Our solution differs from other proposition in the literature because of this dynamic time interval, which allows increasing fairness, reactivity, and in some cases efficiency. In this article, we emphasize the performance evaluation of our proposal.
RR-5958.pdf (336.11 Ko) Télécharger le fichier
inria-00086502 , version 1 (20-07-2006)
inria-00086502 , version 2 (01-08-2006)
Tahiry Razafindralambo, Isabelle Guérin-Lassous, Luigi Iannone, Serge Fdida. Dynamic Packet Aggregation to Solve Performance Anomaly in 802.11 Wireless Networks. [Research Report] RR-5958, INRIA. 2006, pp.28. ⟨inria-00086502v2⟩
154 Consultations
160 Téléchargements
