s'authentifier
version française rss feed
inria-00087029, version 2
Fast computation of the leastcore and prenucleolus of cooperative games
J. Frederic Bonnans () a1, Matthieu Andre b2
N° RR-5956 (2006)
Résumé : The computation of leastcore and prenucleolus is an efficient way of allocating a common resource among $N$ players. It has, however, the drawback being a linear programming problem with $2^N-2$ constraints. In this paper we show how, in the case of convex production games, generate constraints by solving small size linear programming problems, with both continuous and integer variables. The approach is extended to games with symmetries (identical players), and to games with partially continuous coalitions. We also study the computation of prenucleolus, and display encouraging numerical results.
  • Domaine : Mathématiques/Optimisation et contrôle
  • Mots-clés : Cooperative games – coalitions – constraint generation – decomposition – convex production games – symmetric games – aggregate players – nucleolus
  • Référence interne : RR-5956
  • Versions disponibles :  v1 (21-07-2006) v2 (01-08-2006)
  • inria-00087029, version 2
  • oai:hal.inria.fr:inria-00087029
  • Contributeur :
  • Soumis le : Mardi 1 Août 2006, 15:45:38
  • Dernière modification le : Mardi 1 Août 2006, 15:45:50
tous les articles de la base du CCSd...
