CSIRO INEX Experiments: XML Search using PADRE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
This paper reports on the CSIRO group's participation in INEX. We indexed documents and document fragments using PADRE, the core of CSIRO's Panoptic Enterprise Search Engine. A query translator converts the INEX topics into queries containing selection and projection constraints for the results. Answers are extracted from ranked documents and document fragments based on the projection constraints in the query.
vercoustre_inex02.pdf (239.69 Ko) Télécharger le fichier
inria-00090582 , version 1 (31-08-2006)
  • HAL Id : inria-00090582 , version 1
Anne-Marie Vercoustre, James A. Thom, Alexander Krumpholz, Ian Mathieson, Peter R. Wilkins, et al.. CSIRO INEX Experiments: XML Search using PADRE. First Workshop of the Initiative for the Evaluation of XML Retrieval (INEX'02), Dec 2002, Schloss Dagstuhl, Germany, pp.65-72. ⟨inria-00090582⟩
62 Consultations
74 Téléchargements
