s'authentifier
version française rss feed
inria-00090613, version 1
Evaluating signs of determinants using single-precision arithmeti
Francis Avnaim 1, Jean-Daniel Boissonnat () 1, Olivier Devillers () 1, Franco Preparata a2, Mariette Yvinec () 1
Algorithmica 17, 2 (1997) 111-132
Résumé : We propose a method to evaluate signs of 2x2 and 3x3 determinants with b-bit integer entries using only b and (b+1)-bit arithmetic respectively. This algorithm has numerous applications in geometric computation and provides a general and practical approach to robustness. The algorithm has been implemented and experimental results show that it slows down the computing time by only a small factor with respect to floating-point calculation.
  • Domaine : Informatique/Géométrie algorithmique
  • Commentaire : http://www.springerlink.com/content/nlr883hde9w2av31/
  • inria-00090613, version 1
  • oai:hal.inria.fr:inria-00090613
  • Contributeur :
  • Soumis le : Vendredi 1 Septembre 2006, 10:38:07
  • Dernière modification le : Vendredi 1 Septembre 2006, 16:19:37
tous les articles de la base du CCSd...
