s'authentifier
version française rss feed
inria-00090648, version 1
Circular Cylinders by Four or Five Points in Space
Olivier Devillers () a1, Bernard Mourrain () 1, Franco Preparata b2, Philippe Trebuchet () 1
Discrete & Computational Geometry 29, 1 (2002) 83--104
Résumé : We are interested in computing effectively cylinders through 5 points, and in other problems involved in metrology. In particular, we consider the cylinders through 4 points with a fix radius and with extremal radius. For these different problems, we give bounds on the number of solutions and exemples show that these bounds are optimal. Finally, we describe two algebraic methods which can be used here to solve efficiently these problems and some experimentation results.
  • Domaine : Informatique/Géométrie algorithmique
  • Commentaire : http://springerlink.metapress.com/content/w4t22u9hg20thxta/
  • inria-00090648, version 1
  • oai:hal.inria.fr:inria-00090648
  • Contributeur :
  • Soumis le : Vendredi 1 Septembre 2006, 15:59:11
  • Dernière modification le : Vendredi 1 Septembre 2006, 16:16:10
tous les articles de la base du CCSd...
