s'authentifier
version française rss feed
inria-00090668, version 1
A semidynamic construction of higher-order {Voronoi} diagrams and its randomized analysis
Jean-Daniel Boissonnat () a1, Olivier Devillers () a1, Monique Teillaud () a1
Algorithmica 9, 4 (1993) 329-356
Résumé : Thek-Delaunay tree extends the Delaunay tree introduced in [1], and [2]. It is a hierarchical data structure that allows the semidynamic construction of the higher-order Voronoi diagrams of a finite set ofn points in any dimension. In this paper we prove that a randomized construction of thek-Delaunay tree, and thus of all the orderlek Voronoi diagrams, can be done in O(n logn+k 3n) expected time and O(k2n) expected storage in the plane, which is asymptotically optimal for fixedk. Our algorithm extends tod-dimensional space with expected time complexityO(k lceil(d+1)/2rceil+1 n lfloor(d+1)/2rfloor) and space complexityO(k lceil(d+1)/2rceil n lfloor(d+1)/2rfloor). The algorithm is simple and experimental results are given.
  • Domaine : Informatique/Géométrie algorithmique
  • Commentaire : http://www.springerlink.com/content/g22m7463281647rl/
  • inria-00090668, version 1
  • oai:hal.inria.fr:inria-00090668
  • Contributeur :
  • Soumis le : Vendredi 1 Septembre 2006, 13:48:25
  • Dernière modification le : Vendredi 1 Septembre 2006, 16:56:19
tous les articles de la base du CCSd...
