Multi-Object Checking Counterexamples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Model checking has become the most widely used technique for the verification of state based systems. In addition to its automation in checking whether a system model satisfies a specification, model checking provides a counterexample trace if the checking condition does not hold. Such a sequence of states illustrates how the model falsifies the specification. Multi-object checking utilizes model checking as the underlying verification technique for each object so that the verification of a system is only limited by the state space of the largest object. Our contribution proposes an enhancement to multi-object checking -- the automated generation of a global system trace, if a specification in multi-object logic does not hold.
AVOCS.pdf (132.19 Ko) Télécharger le fichier
inria-00091663 , version 1 (06-09-2006)
  • HAL Id : inria-00091663 , version 1
Maik Kollmann, Yuen Man Hon. Multi-Object Checking Counterexamples. Automatic Verification of Critical Systems, Sep 2006, Nancy/France, pp.163-167. ⟨inria-00091663⟩
Collections
AVOCS06
64 Consultations
150 Téléchargements
