A method to refine time constraints in event B framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Joris Rehm
  • Fonction : Auteur
  • PersonId : 756920
  • IdRef : 142454303
Some software or hardware system involves time constraints. When those constraints are required to express the behaviour of the system, we need to write them in the corresponding formal model. We show in this short paper the general method used to deal with time constraints with a simple application example. This applies for event B formal method which does not have specific notions for time and uses the refinement to introduce it.
avocs.pdf (92.06 Ko) Télécharger le fichier
inria-00091665 , version 1 (06-09-2006)
  • HAL Id : inria-00091665 , version 1
Joris Rehm. A method to refine time constraints in event B framework. Automatic Verification of Critical Systems - AVoCS 2006, Sep 2006, Nancy/France, pp.173-177. ⟨inria-00091665⟩
102 Consultations
129 Téléchargements
