A Multi-HMM Approach to ECG Segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Julien Thomas
  • Fonction : Auteur
  • PersonId : 835105
Cédric Rose
  • Fonction : Auteur
  • PersonId : 830760
Pharmaceutic studies require to analyze thousands of ECGs in order to evaluate the side effects of a new drug. In this paper we present a new approach to automatic ECG segmentation based on hierarchic continuous density hidden Markov models. We applied a wavelet transform to the signals in order to highlight the discontinuities in the modeled ECGs. A training base of standard 12-lead ECGs segmented by cardiologists was used to evaluate the performance of our method. We used a Bayesian HMM clustering algorithm to partition the training base, and we improved the method by using a multi-model approach. We present a statistical analysis of the results where we compare different automatic methods to the segmentation of the cardiologist.
thomas-rose-06.pdf (342.64 Ko) Télécharger le fichier
inria-00095437 , version 1 (11-09-2007)
Julien Thomas, Cédric Rose, François Charpillet. A Multi-HMM Approach to ECG Segmentation. 18th IEEE International Conference on Tools with Artificial Intelligence - ICTAI'06, Nov 2006, Washington D.C., United States. pp.609-616, ⟨10.1109/ICTAI.2006.17⟩. ⟨inria-00095437⟩
105 Consultations
460 Téléchargements
