Modular self-organization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Bruno Scherrer
The aim of this paper is to provide a sound framework for addressing a difficult problem: the automatic construction of an autonomous agent's modular architecture. We combine results from two apparently uncorrelated domains: Autonomous planning through Markov Decision Processes and a General Data Clustering Approach using a kernel-like method. Our fundamental idea is that the former is a good framework for addressing autonomy whereas the latter allows to tackle self-organizing problems.
article.pdf (218.23 Ko) Télécharger le fichier
inria-00098315 , version 1 (25-09-2006)
Bruno Scherrer. Modular self-organization. [Research Report] 2003, pp.16. ⟨inria-00098315⟩
78 Consultations
52 Téléchargements
