inria-00098431, version 1
Modeling Adaptive Organizations
Rémy Foisel 1Vincent Chevrier
Jean-Paul Haton
Third International Conference on Multi-Agent Systems - ICMAS'98 (1998) 2 p
Résumé : We present in this paper a model based on the notion of interaction to build adaptive organizations. Interaction models are used to provide an initial organizational structure to the system. Local assessment capacities are added to make agents adapt the structure according to their requirements. This model is used to build a multi-agent system with global coherent behavior through the use of organizational structure and with abilities to make the system adapt its structure when it is not locally convenient.
- 1 : MAIA (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
- Domaine : Informatique/Autre
- Mots-clés : adaptive organization – interaction – multi-agent systems || organisation adaptative – systèmes multi-agents
- Référence interne : 98-R-029 || foisel98a
- Commentaire : Colloque avec actes et comité de lecture.
- inria-00098431, version 1
- http://hal.inria.fr/inria-00098431
- oai:hal.inria.fr:inria-00098431
- Contributeur : Publications Loria
- Soumis le : Lundi 25 Septembre 2006, 17:01:18
- Dernière modification le : Jeudi 28 Septembre 2006, 15:22:44
Exporter
