Inversion of parameterized hypersurfaces by means of subresultants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We present a subresultant-based algorithm for deciding if the parametrization of a toric hypersurface is invertible or not, and for computing the inverse of the parametrization in the case where it exists. The algorithm takes into account the monomial structure of the input polynomials.
issac04.pdf (144.2 Ko) Télécharger le fichier
inria-00098678 , version 1 (25-09-2006)
  • HAL Id : inria-00098678 , version 1
Laurent Busé, Carlos d'Andrea. Inversion of parameterized hypersurfaces by means of subresultants. Internation Symposium on Symbolic and Algebraic Computing (ISSAC), Jul 2004, Santander, Spain, pp.65--71. ⟨inria-00098678⟩
106 Consultations
142 Téléchargements
