Implicitization of surfaces in the projective space in the presence of base points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra and Its Applications Année : 2003
We show that the method of moving quadrics for implicitizing surfaces in $\PP^3$ applies in certain cases where base points are present. However, if the ideal defined by the parametrization is saturated, then this method rarely applies. Instead, we show that when the base points are a local complete intersection, the implicit equation can be computed as the resultant of the first syzygies.
bcd.pdf (296.79 Ko) Télécharger le fichier
inria-00098684 , version 1 (25-09-2006)
  • HAL Id : inria-00098684 , version 1
Laurent Busé, David Cox, Carlos d'Andrea. Implicitization of surfaces in the projective space in the presence of base points. Journal of Algebra and Its Applications, 2003, 2 (2), pp.189--214. ⟨inria-00098684⟩
139 Consultations
160 Téléchargements
