s'authentifier
version française rss feed
inria-00098772, version 2
Locked and Unlocked Polygonal Chains in Three Dimensions
Thérèse Biedl a1, Erik Demaine a1, Martin Demaine a1, Sylvain Lazard b2, Anna Lubiw a1, Joseph O'Rourke c3, M. Overmars d4, Steve Robbins e5, Ileana Streinu f3, Godfried Toussaint e5, Sue Whitesides e5
Symposium on Discrete Algorithms - SODA'99 (1999) 866 - 867
Résumé : This paper studies movements of polygonal chains in three dimensions whose links are not allowed to cross or change length. Our main result is an algorithmic proof that any simple closed chain that initially takes the form of a planar polygon can be made convex in three dimensions. Other results include an algorithm for straightening open chains having a simple orthogonal projection onto some plane, and an algorithm for making convex any open chain initially configured on the surface of a polytope. All our algorithms require only O(n) basic ``moves.''
  • Domaine : Informatique/Autre
  • Mots-clés : linkages || mécanismes articulés
  • Référence interne : A01-R-188 || biedl01a
  • Commentaire : ISBN: 0-89871-434-6
  • Versions disponibles :  v1 (28-09-2006) v2 (19-11-2010)
  • inria-00098772, version 2
  • oai:hal.inria.fr:inria-00098772
  • Contributeur :
  • Soumis le : Vendredi 19 Novembre 2010, 14:12:10
  • Dernière modification le : Lundi 22 Novembre 2010, 16:59:13
tous les articles de la base du CCSd...
