inria-00099008, version 1
Scilab//: User interactive application and high performances
Frédéric Desprez a, 1Eric Fleury
a, 2Laura Grigori b, 2
Third World Multiconference on Systemics, Cybernetics & Informatics - SCI'99 & Fifth International Conference on Information Systems Analysis & Synthesis - ISAS'99 (1999)
Résumé : Scilab, developed at INRIA in the Méta2 project is a software similar to Matlab that allows scientific applications to be developed using an interactive environment on a workstation running Unix or Windows. In this paper, we present the current version of Scilab, a extension of this software that supports the execution of parallel jobs within Scilab. Using simple commands and the same interface as Scilab, Scilab//\ allows users to start Scilab on a parallel machine or a network of workstations (NOWs), therefore giving access to the computation power and huge aggregate memory sizes. From the Scilab interactive environment, users can spawn several other Scilab processes, executing remote Scilab scripts, which can then communicate between each other. Finally, processes can print/plot their results. There are many research directions around this project and we give an overview of the current and future developments.
- a – INRIA
- b – UNIVERSITE HENRI POINCARE
- 1 : REMAP (INRIA Rhône-Alpes / LIP Laboratoire de l'Informatique du Parallélisme)
- INRIA – École Normale Supérieure - Lyon – CNRS : UMR5668 – LIP
- 2 : RESEDAS (INRIA Lorraine - LORIA)
- INRIA – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL) – CNRS : UMR7503
- Domaine : Informatique/Autre
- Mots-clés : parallel machines – nows – meta-computing – pvm – parallelization tools – numerical applications. || metacomputing – cluster – application numérique
- Référence interne : 99-R-146 || desprez99b
- Commentaire : Colloque avec actes et comité de lecture. internationale.
- inria-00099008, version 1
- http://hal.inria.fr/inria-00099008
- oai:hal.inria.fr:inria-00099008
- Contributeur : Publications Loria
- Soumis le : Mardi 26 Septembre 2006, 08:41:10
- Dernière modification le : Jeudi 11 Janvier 2007, 11:54:57
Exporter
