Factorization of a 512-bit RSA Modulus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Bruce Dodson
  • Fonction : Auteur
Arjen K. Lenstra
  • Fonction : Auteur
Walter Lioen
  • Fonction : Auteur
Peter L. Montgomery
  • Fonction : Auteur
Brian Murphy
  • Fonction : Auteur
Herman Te Riele
  • Fonction : Auteur
Karen Aardal
  • Fonction : Auteur
Jeff Gilchrist
  • Fonction : Auteur
Gérard Guillerm
  • Fonction : Auteur
Paul Leyland
  • Fonction : Auteur
Joël Marchand
François Morain
Alec Muffett
  • Fonction : Auteur
Chris Putnam
  • Fonction : Auteur
Craig Putnam
  • Fonction : Auteur
On August 22, 1999, we completed the factorization of the 512--bit 155--digit number RSA--155 with the help of the Number Field Sieve factoring method (NFS). This is a new record for factoring general numbers. Moreover, 512--bit RSA keys are frequently used for the protection of electronic commerce---at least outside the USA---so this factorization represents a breakthrough in research on RSA--based systems. The previous record, factoring the 140--digit number RSA--140, was established on February 2, 1999, also with the help of NFS, by a subset of the team which factored RSA--155. The amount of computing time spent on RSA--155 was about 8400 MIPS years, roughly four times that needed for RSA--140; this is about half of what could be expected from a straightforward extrapolation of the computing time spent on factoring RSA--140 and about a quarter of what would be expected from a straightforward extrapolation from the computing time spent on RSA--130. The speed-up is due to a new polynomial selection method for NFS of Murphy and Montgomery which was applied for the first time to RSA--140 and now, with improvements, to RSA--155.
Autre [cs.OH]
inria-00099117 , version 1 (26-09-2006)
Stefania Cavallar, Bruce Dodson, Arjen K. Lenstra, Walter Lioen, Peter L. Montgomery, et al.. Factorization of a 512-bit RSA Modulus. International Conference on the Theory and Application of Cryptographic Techniques - EUROCRYPT 2000, May 2000, Bruges, Belgium. pp.1-18, ⟨10.1007/3-540-45539-6_1⟩. ⟨inria-00099117⟩
394 Consultations
0 Téléchargements
