On the Number of Lines Tangent to Four Convex Polyhedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
We prove that, under a certain general position assumption, the number of lines tangent to four bounded disjoint convex polyhedra in $\Real^3$ with a total of $n$ edges is $O(n^2)$. Under the same assumption, we show that a set of $k$ bounded disjoint convex polyhedra has at most $O(n^2k^2)$ lines, possibly occluded, that are tangent to four of these polyhedra.
Autre [cs.OH]
A02-R-268.pdf (198.16 Ko) Télécharger le fichier
inria-00099449 , version 1 (15-12-2009)
  • HAL Id : inria-00099449 , version 1
Hervé Brönnimann, Olivier Devillers, Vida Dujmovic, Hazel Everett, Marc Glisse, et al.. On the Number of Lines Tangent to Four Convex Polyhedra. 14th Canadian Conference on Computational Geometry - CCCG'02, 2002, Lethbridge, Canada. ⟨inria-00099449⟩
207 Consultations
299 Téléchargements
