Residual resultant over the projective plane and the implicitization problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this article, we first generalize the recent notion of residual resultant of a complete intersection to the case of a local complete intersection of codimension 2 in the projective plane, which is the necessary and sufficient condition for a system of three polynomials to have a solution ``outside'' a variety, defined here by a local complete intersection of codimension 2. We give its degree in the coefficients of each polynomial and compute it as the gcd of three polynomials or as a product of two determinants divided by another one. In a second part we use this new type of resultant to give a new method to compute the implicit equation of a rational surface with base points in the case where these base points are a local complete intersection of codimension 2.
implicit.pdf (203.24 Ko) Télécharger le fichier
errata.pdf (9.77 Ko) Télécharger le fichier
inria-00099846 , version 1 (26-09-2006)
  • HAL Id : inria-00099846 , version 1
Laurent Busé. Residual resultant over the projective plane and the implicitization problem. Internation Symposium on Symbolic and Algebraic Computing (ISSAC), Jul 2001, London, Ontario, Canada. pp.48--55. ⟨inria-00099846⟩
253 Consultations
470 Téléchargements
