Proving weak termination also provides the right way to terminate - Extended version - - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
We give an inductive method for proving weak innermost termination of rule-based programs, from which we automatically infer, for each successful proof, a finite strategy for data evaluation. We first present the proof principle, using an explicit induction on the termination property, to prove that any input data has at least one finite evaluation. For that, we observe proof trees built from the rewrite system, schematizing the innermost rewriting tree of any ground term, and generated with two mechanisms: abstraction, schematizing normalization of subterms, and narrowing, schematizing rewriting steps. Then, we show how, for any ground term, a normalizing rewriting strategy can be extracted from the proof trees, even if the ground term admits infinite rewriting derivations.
A04-R-522.pdf (375.84 Ko) Télécharger le fichier
inria-00099872 , version 1 (19-06-2009)
  • HAL Id : inria-00099872 , version 1
Olivier Fissore, Isabelle Gnaedig, Hélène Kirchner. Proving weak termination also provides the right way to terminate - Extended version -. [Intern report] A04-R-522 || fissore04b, 2004, 54 p. ⟨inria-00099872⟩
191 Consultations
58 Téléchargements
