Combining Higher-Order Wavelets and Discontinuity Meshing: a Compact Representation for Radiosity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The radiosity method is used for global illumination simulation in diffuse scenes, or as an intermediate step in other methods. Radiosity computations using Higher-Order wavelets achieve a compact representation of the illumination on many parts of the scene, but are more expensive near discontinuities, such as shadow boundaries. Other methods use a mesh, based on the set of discontinuities of the illumination function. The complexity of this set of discontinuities has so far proven prohibitive for large scenes, mostly because of the difficulty to robustly manage a geometrically complex set of triangles. In this paper, we present a method for computing radiosity that uses higher-order wavelet functions as a basis, and introduces discontinuities only when they simplify the resulting mesh. The result is displayed directly, without post-processing.
Autre [cs.OH]
Electronic.pdf (8.01 Mo) Télécharger le fichier
Format : Figure, Image
inria-00100041 , version 1 (30-11-2009)
  • HAL Id : inria-00100041 , version 1
Nicolas Holzschuch, Laurent Alonso. Combining Higher-Order Wavelets and Discontinuity Meshing: a Compact Representation for Radiosity. Eurographics Symposium on Rendering 2004 - EGSR 2004, Jun 2004, Norrköping, Sweden. pp.275-286. ⟨inria-00100041⟩
357 Consultations
330 Téléchargements
