Reference Resolution within the Framework of Cognitive Grammar - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Following the principles of Cognitive Grammar, we concentrate on a model for reference resolution that attempts to overcome the difficulties previous approaches, based on the fundamental assumption that all reference (independent on the type of the referring expression) is accomplished via access to and restructuring of domains of reference rather than by direct linkage to the entities themselves. The model accounts for entities not explicitly mentioned but understood in a discourse, and enables exploitation of discursive and perceptual context to limit the set of potential referents for a given referring expression. As the most important feature, we note that a single mechanism is required to handle what are typically treated as diverse phenomena. Our approach, then, provides a fresh perspective on the relations between Cognitive Grammar and the problem of reference.
csq.pdf (489.31 Ko) Télécharger le fichier
ICCS-02.ppt (166 Ko) Télécharger le fichier
Format : Autre
inria-00100430 , version 1 (14-09-2009)
  • HAL Id : inria-00100430 , version 1
  • ARXIV : 0909.2626
Susanne Salmon-Alt, Laurent Romary. Reference Resolution within the Framework of Cognitive Grammar. International Colloqium on Cognitive Science, 2001, San Sebastian, Spain. 16 p. ⟨inria-00100430⟩
160 Consultations
132 Téléchargements
