Standards for Language Resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The goal of this paper is two-fold: to present an abstract data model for linguistic annotations and its implementation using XML, RDF and related standards; and to outline the work of a newly formed committee of the International Standards Organization (ISO), ISO/TC 37/SC 4 Language Resource Management, which will use this work as its starting point.
IRCS-2.pdf (66.25 Ko) Télécharger le fichier
ide.ppt (118 Ko) Télécharger le fichier
Format : Autre
inria-00100589 , version 1 (09-11-2009)
  • HAL Id : inria-00100589 , version 1
  • ARXIV : 0911.1842
Nancy Ide, Laurent Romary. Standards for Language Resources. IRCS 2001 - Workshop on Linguistic Databases, Steven Bird, Peter Buneman and Mark Liberman, Nov 2001, Philadelphia, United States. ⟨inria-00100589⟩
110 Consultations
142 Téléchargements
