Enabling Transparent Data Sharing in Component Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The fast growth of high-bandwidth wide-area networks has encouraged the development of computational grids. To deal with the increasing complexity of grid applications, the software component technology seems very appealing since it emphasizes software composition and re-use. However, current software component models only support explicit data transfers between components. The distributed shared memory paradigm has demonstrated its utility by enabling a transparent access to data via a globally shared data space. This paper proposes to extend software component models with shared memory capabilities, enabling transparent access to shared data across components and leading to further decreased software complexity.
AntBouBreJanPer-CCGrid06.pdf (226.11 Ko) Télécharger le fichier
inria-00101363 , version 1 (26-09-2006)
  • HAL Id : inria-00101363 , version 1
Gabriel Antoniu, Hinde Lilia Bouziane, Landry Breuil, Mathieu Jan, Christian Pérez. Enabling Transparent Data Sharing in Component Models. 6th IEEE International Symposium on Cluster Computing and the Grid (CCGRID~'06), May 2006, Singapore, Japan. pp.430-433. ⟨inria-00101363⟩
125 Consultations
114 Téléchargements
