Combining Data Sharing with the Master-Worker Paradigm in the Common Component Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Software component technologies are being accepted as an adequate solution for handling the complexity of applications. However, existing software component models tend to be specialized to some types of resource architectures (e.g. in-process, distributed environments, etc) and/or do not provide a very high level of abstraction. This paper focuses on handling \emph{data sharing} on operation invocations between components as a solution allowing applications to be efficiently executed on all kinds of resources. In particular, the data sharing pattern appears in master-worker applications, when workers need to access only a part of a large piece of data, either in read or write mode. This approach is applied to the Common Component Architecture model. Its benefits are discussed using an image rendering application.
Mots clés
AntBouJanPerPri-HPC-GECO06.pdf (326.15 Ko) Télécharger le fichier
inria-00101365 , version 1 (26-09-2006)
  • HAL Id : inria-00101365 , version 1
Gabriel Antoniu, Hinde Lilia Bouziane, Mathieu Jan, Christian Pérez, Thierry Priol. Combining Data Sharing with the Master-Worker Paradigm in the Common Component Architecture. Joint Workshop on HPC Grid programming Environments and COmponents and Component and Framework Technology in High-Performance and Scientific Computing (HPC-GECO/CompFrame~2006), Jun 2006, Paris, France. pp.10-18. ⟨inria-00101365⟩
161 Consultations
194 Téléchargements
