A Monte Carlo Method to Compute the exchange coefficient in the double porosity model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The double porosity model allows to compute the pressure at a macroscopic scale in a fractured porous media, but requires the computation of some exchange coefficient characterizing the passage of the fluid from and to the porous media (the matrix) and the fractures. We propose a new Monte Carlo method to estimate this coefficient. Here we give an overview of some article from F. Campillo and A. Lejay
Proceedings-Monte-Carlo2000-campillo-lejay.pdf (167.64 Ko) Télécharger le fichier
inria-00101707 , version 1 (28-09-2006)
  • HAL Id : inria-00101707 , version 1
Fabien Campillo, Antoine Lejay. A Monte Carlo Method to Compute the exchange coefficient in the double porosity model. Monte Carlo and probabilistic methods for partial differential equations (Monte Carlo, 2000), 2000, Monte Carlo, pp.65-72. ⟨inria-00101707⟩
151 Consultations
136 Téléchargements
